2001gr caravan cooling rand
Old May 20, 2011 | 08:22 PM
topflightusa's Avatar
topflightusa
Default 2001gr caravan cooling rand
My cooling fans areonly getting 9.5 volts to them the relay is good and the fans work witb 12 volts. Any help appriciated
Old May 21, 2011 | 12:24 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Okay, you are saying the fans don't work unless you apply 12 volts to the curcuit?
Old May 21, 2011 | 10:07 AM
Tizzy1's Avatar
Tizzy1
The wire is corroded causing high resistance. It usually gets damaged down by the bottom of the radiator on the drivers side. You need to find the bad spot in the harness and repair it.
Old May 24, 2011 | 08:21 PM
topflightusa
so i checked the wires their good no connection between neg n pos..so no short.both fans work when i put 12 v to them..actually running them with a toggle switch ..but i found the fuse but cant find the relay that turns them on..and my temp gauge works in the cluster..im baffled
Old May 24, 2011 | 08:25 PM
topflightusa
and i thankyou. I did check that wire harness too it was good
Old May 25, 2011 | 10:30 PM
topflightusa
Ok so the wires arent shorted..i cant find the fan relay its not in the fusebox under the hood
Old May 28, 2011 | 11:43 AM
Tizzy1's Avatar
Tizzy1
Sorry so late, very busy at work. The radiator fan relay is attached to the front bumper reinforcement behind the fascia.
Old May 28, 2011 | 11:45 AM
Tizzy1's Avatar
Tizzy1
here's a wiring diagram
Old May 28, 2011 | 05:51 PM
topflightusa
Thanks i got a new one just haven't got it on yet 65.00 at napa
