I have a loud noise in my 1996 caravan
I have a 1996 dodge caravan.I have been having a loud noise coming from the drivers side. I think it is my trans-axle but I am not seeing anything wrong. There is a slight woble in the steering wheel that was not there before.
- Clunking when you go over bumps suspect sway bar bushings or links.
- Whirring or roaring (which increases in pitch or volume with increased speed) while driving on smooth surface suspect hub or axle bearing.
- clicking or clacking when turning a corner suspect CV joint.
