Fuel Tank Vacuum...
Old May 26, 2011 | 07:50 PM
arielstr's Avatar
arielstr
Exclamation Fuel Tank Vacuum...2005 Caravan
2005 Dodge Caravan SXT
Hello Everybody...it start to happen four days ago, when I tried to fill up the fuel tank the pump kick off every two gallons and when I run my van the fuel gauge start to go down (higher RPM, faster empty reads/ low RPM, slow empty reads) and when I remove the fuel tank cap sounds like the tank take a huge breathe, but if I remove the fuel tank cap does not happen.....Can somebody help me please? Thanks!!!!
Ariel.
Old May 26, 2011 | 11:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you had any work does on the van? You need tio have the problem looked at. You may have a pinch vapor hose or vent valve.
Old May 27, 2011 | 08:54 PM
arielstr's Avatar
arielstr
Hello and Thanks for your fast reply!!! Yes, I change the flexplate last week but I found the problem....the problem was the evap purge solenoid lines, "they were reversed"....(my mistake) Thanks again!!!!...and I will pay more attention the next time.""
Ariel.
Old May 27, 2011 | 11:03 PM
master tech
Thank you for posting the fix.
