2001 van a/c not working.
Old May 26, 2011 | 02:32 PM
Bigracer-x's Avatar
Bigracer-x
Default 2001 van a/c not working.
I have a 2001 dodge mini van, the a/c does not work , has no pwer to compressor clutch, changed relay still no fix, any suggestions? Does any one have a wire diagram for the a/c system? If I Dont get this fixed my wife will kill me!
Old May 26, 2011 | 11:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Did you know if the a/c system has freon in it? And did you ck the fuses?
Old May 27, 2011 | 08:19 AM
Bigracer-x's Avatar
Bigracer-x
Thanks for your help, the fuse is good and the system is serviced. I had actually took it to Pep boys, they had it for three days, they tolld me , the control unit is not allowing the relay to close, and they did not have the right computer to diagnose the problem. They said I should take it to the dealer. The dealer is booked full for a week, so I am trying to fix it myself and save a few bucks.
Old Jun 3, 2011 | 09:04 PM
multimedia51's Avatar
multimedia51
hey I was just wondering how you made out with this problem as I am having the same issue.
Old Jun 22, 2011 | 01:37 PM
Bigracer-x's Avatar
Bigracer-x
I removed the a/c relay, and added a secondary switch under the dash, a/c works ok now. Sometime you have to be smarter than the average bear. ( save some $$$)
Old Jun 22, 2011 | 03:25 PM
Tizzy1's Avatar
Tizzy1
Til the compressor blows up because it can't cycle.
Old Jun 22, 2011 | 03:30 PM
Tizzy1's Avatar
Tizzy1
Basically a pretty simple system. The PCM looks at the pressure transducer and makes sure the pressure is in range. It also looks for the switch being pressed on the control panel. It grounds the relay to engage the clutch. the early years of the RS minivan ('01 - '03), the compressor would run itself low on oil and overheat. It might blow itself up internally or possibly melt the clutch out. Pretty common. So first check for freon in the system. Then jump the clutch to see if the compressor works. Then you might need access to a scan tool
Old Nov 4, 2011 | 06:33 PM
Bigracer-x's Avatar
Bigracer-x
I ran the A/c with the temp switch for a couple of monthes, until it locked up one day. Took it to dealer, compressor was still good ( smile) but the changed a temperture sensor in air duct, works great now. Thanks Tizzy1
Old Nov 5, 2011 | 06:03 PM
scotter5's Avatar
scotter5
Is the temperature sensors in the auto temp control only. i have 06 caravan with a/c slide controls
