Broken Plug on 92 Grand Caravan 3.3L
Old Jun 3, 2011 | 10:14 PM
Ramvan1's Avatar
Ramvan1
Default Broken Plug on 92 Grand Caravan 3.3L
Well the first three plugs took 5 mins. the rear three have been 10 hours worth of work and counting I got 2 of the rear plugs out after wrestling getting the boots off for 1 hour then I realized the middle plug appeared to be crooked and after working all morning on it most of the ceramic piece broke off and now I can barely see the hole and the threads do not want to come loose any ideas.
Old Jun 4, 2011 | 06:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
Was the one plug cross thread before you started or after? Did you try soaking the plug with WD40?
Old Jun 4, 2011 | 09:27 PM
Ramvan1's Avatar
Ramvan1
It was cross threaded before and I sprayed it with WD40 and PB Blaster
