obd2 wont read my 98 grand caravan?
Old 06-04-2011 | 05:59 PM
doane88's Avatar
doane88
Default obd2 wont read my 98 grand caravan?
-hey everyone.
im trying to get my 98 dodge grand caravan inspected but the obd2 wont even read at all. tried to hook it up a number of times. i checked the obd2 prongs on the van with a electrical circuit tester and could only get one prong to light up if that helps at all. ne one have ne suggestions that might be able to help me out? thanks in advance.
~Josh
Old 06-04-2011 | 07:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Does the screen come on at all when you plug into the DLC? If it doesn't ck the fuses, I think its fuse 23.
Old 06-14-2011 | 09:28 PM
doane88's Avatar
doane88
Originally Posted by master tech
Welcome to DF
Im not quit sure. my mother went to get it inspected and the guy she spoke to said it wouldnt read ne thing. i kno we went to auto zone and tried to hook it up to a pocket scanner and it just said searching or something like that and didnt come up with ne thing. i checked all the fuses under the hood and they seemed to be alright besides the plastic on relay 4608650 was broken but seemed to be alright inside. the whole outer plastic shell came off when i went to pull it out. i didnt notice a 23fuse? i looked under the dashboard under the steering wheel and did notice it was missing relay 1-2-5-6-7-8-11-12-drl3. i hope maybe something there might help out.
-Josh
Old 06-15-2011 | 02:42 PM
doane88's Avatar
doane88
Bump.
Old 06-17-2011 | 09:40 AM
doane88's Avatar
doane88
Bump.
Old 06-17-2011 | 06:29 PM
Cougar41's Avatar
Cougar41
Fuses good? Disconnect the negative battery cable a few minutes. Still dead? Probably a bad powertrain control module better known as a PCM or wiring.
Old 06-18-2011 | 12:18 AM
master tech
What type of scanner are you using?
Old 06-20-2011 | 12:16 AM
doane88's Avatar
doane88
im not sure what scanner the guy used at the inspection place. i wasnt there when my mom tried to get it inspected. im guessing the standard machine they use to to hook up to the obd2 at an inspection place? we even went to auto zone and used a pocket scanner to see what would happen and nothing. it just said searching or scanning or something like that, and then nothing popped up. maybe it the obd2 system itself is junk?
Old 06-20-2011 | 12:28 AM
master tech
You may need to have the dealer to ck codes with a DRB3 scanner and if the screen reads blank, they would be able to ck the problem.
Old 06-20-2011 | 12:41 AM
doane88's Avatar
doane88
ok. thanks for all your help. was trying to avoid going to the dealer but seems like that is my the only option. will lyk when i have the solution.
