95 caravan , front end vibrations?
Old Jun 5, 2011 | 10:15 AM
caravanman1966's Avatar
caravanman1966
Default 95 caravan , front end vibrations?
I have a 1995 dodge caravan 2.5 , 3 spd automatic caravan.
The problem is when you give it gas at any speed the front end shakes.
I replaced the passenger side drive axle/c/v, and it still shakes.
The one thing i have noticed is it will only do this while in drive giving it gas, it wont do it in neutral coasting , and is worse going up hill.
?....could the other axle be the problem?
..... could it be the transmission?
This all happened out of the blue with no other issues .
thanks
Old Jun 5, 2011 | 10:28 AM
Tizzy1's Avatar
Tizzy1
does it do it in a slight turn? That usually indicates axle. Maybe check for worn mounts too.
Old Jun 5, 2011 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I agree with tizzy, you may have either bad motor mounts or drive axles.
Old Jun 6, 2011 | 08:54 AM
caravanman1966
Im gonna take a look , while its on a lift today . Ill post back as to my findings .
thanks
