My 2003 Grand Caravan Sport rear A/C issue
Old Jun 8, 2011 | 05:23 PM
Geerhed's Avatar
Geerhed
Default My 2003 Grand Caravan Sport rear A/C issue
Hi all, i would like to post my first thread about my van. Great van, and it's been treating us here very well.
I do have a problem with the A/C though. I just got it repaired last year, and now the back A/C isn't blowing cold air!
I think there's a vacuum line off or just a loose wire somewhere, but not sure where to look first!
The front A/C is nice and cold by the way.Just wondering if anyone else has this problem, or knows of the solution for the home garage guy.
Old Jun 8, 2011 | 05:40 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Caravan section,
FF
Old Jun 8, 2011 | 06:22 PM
steak59's Avatar
steak59
what did they atually repair? did the rear A/C work "right after" the repair? or did they removed the rear A/C unit due it cost?
Old Jun 8, 2011 | 08:30 PM
scotter5's Avatar
scotter5
MOst likely the rear expansion valve located inside of the rear inside panel of the van. See attachment for explanation: http://www.youtube.com/watch?v=S8sYR...eature=related
I replaced the expansion valve. the part was 35 bucks. This is common weakness in these vans. rear valve goes out. then you need to refill system with 134a around 3 cans and first vacuum line, although mine wasn't because i didn't have the money to get it done, and soon as opening of the line of the rear expansion valve i plugged a/c line with a cork or run tape over it.
If you put a a/c compressor in when you had it repaired, then i wish you knew if it was flushed out because of metal pieces that maybe lodged within the a/c line in the rear stopping up the gas, liquid from going back to rear.
Somebody else please chime in and find away for this gentlemen to troubleshoot other then what i told him.
scott
Old Jun 9, 2011 | 12:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Old Jun 9, 2011 | 07:04 PM
Geerhed's Avatar
Geerhed
Hi all and thanks for the replies! Yes all the air was working both front and back when i got it repaired last year.
Now all i have is the front air, and it's working just fine.
The rear air did working once last week, but now it's just blowing out warm air.
I have tried both with the recirculating inside air on and off too.
Guess i may have to drop the panel form the inside roof of the van that also houses the DVD player and air controls, just to take a peak.
There are two ***** there, one to choose the intensity of airflow, and the other for warm or cold air!
Old Jun 9, 2011 | 08:11 PM
steak59's Avatar
steak59
so you either got a broken Blend door or Stuck H-block/expansion valve.
Does Heat work for the rear? if it does, then the blend door should be fine. ur problem is probably the H-Block as posted.
