ac/heater issue
Old Jun 20, 2011 | 01:17 PM
gerbera's Avatar
gerbera
Default ac/heater issue
2003 dodge caravan, ac/heater blows normally in the back setting. The front setting, is almost not existant, no, high, no medium ,but the low is so slight I can barely feel it, I cannot hear the blower on the front, mechanic says it could be a wiring harness? any help would eb appreciated
Old Jun 20, 2011 | 03:14 PM
Tizzy1's Avatar
Tizzy1
most of the time it is a resistor issue. Power is supplied to the blower motor and then grounded through the resistor. Depending on the wire that is grounded is what speed you get.
Old Jun 27, 2011 | 03:18 PM
gerbera's Avatar
gerbera
Motor resistor, was not the fix, replaced and still the same, back blower works, front blower not, any other possible solutions, thanks, Bobbie
Old Jun 27, 2011 | 03:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
It maybe the motor itself. Thats why tizzy said most of the time it maybe the resistor. In 99% of the time that would be the cause. The other 1% maybe wiring or a motor. I would try a known good motor, before replacing the motor.
Old Jun 27, 2011 | 04:43 PM
Cougar41's Avatar
Cougar41
Old Jun 27, 2011 | 04:49 PM
Cougar41's Avatar
Cougar41
Key at on/run, check for 12vdc at the blower motor connector. If it's there and the ground is good change the blower motor. A multimeter or even a test light will save you bucks, time, and many headaches.
