wiper blades
Old Jun 20, 2011 | 01:32 PM
emerald's Avatar
emerald
Default wiper blades
I own a 2000 Dodge Grand Caravan. After a heavy rainfall I will get water inside of my car. When I accelerate a water fall of water comes rushing down to the floor from between the firewall and my dashboard. I am fairly certain that this is due to to the seal between the windshield and the vent cover deteriorating. I took out the strip of molding that touches the windshield and I want to be able to take the vent cover off so I can clean the old silicon away and re-seal it.
My question is that to do this I must take the whole wiper blade off. I took the nut off at the base of the arm but I am stuck as to how to get the arm off. Do I turn it counter clockwise? I just do not want to break it. Any help on this topic will be greatly appreciated.
Old Jun 20, 2011 | 10:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would check the drains on each side of the wiper module. Make sure the drains are clear.
Old Jun 26, 2011 | 04:47 AM
peshewa's Avatar
peshewa
And if you need to remove the wiper arms, the nut comes off then the arm I think is splined and needs to be wiggled gently strait off the shaft. It helps to use a marker of some kind to put them back on in the same spot they came off too.
