2000 Caravan Transmission Help
Old Jul 7, 2011 | 11:33 PM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the pump and the pressure valve is under the front pump gasket. It will be sticking up a bit from the case. Make sure all you seals and seal rings are on the pump too.
Old Jul 8, 2011 | 08:30 PM
23bobbyg's Avatar
23bobbyg
Well removed tranny and purchased new bypass valve and pump. went to install new pump (came as two pieces) and noticed the pump I received had a 12 tooth internal gear and the old pump had 24. I have to wait till Monday to return it so I was wondering if I can safely use the 12 tooth pump or do I need to return it?
