vac a/c system
I may sound crazy but can i vac out my a/c lines with a strong wet vac. I have all the connectors and did it on my house a/c line before. If you say NO. Then why?
i don't have a vac system. there 80 bucks and guy at shop wants 78 bucks vac the system. the 134 has all been removed from the system. i am putting in compressor and accumulator.
The whole idea of evacuating the system is to lower the pressure inside the system to the point that any moisture will evaporate (boil). A wet dry vacuum will simply not pull this amount of vacuum. You need 28.5 inches of mercury to effectively do this. Are you using a gauge set? How far down will your vacuum pull the system? Go to http://www.harborfreight.com/air-vac...ors-96677.html . This is the minimum you should use. You just need an air compressor
Thanks for responses. As mentioned in opening thread. don't have 80 bucks for the vac. But wanted to know if a wet vac could work and if not WHY? Interesting in understanding why. I believe i have answers from you guys.
Guy I ran into had a vac that can be used.
scott--thanks everyone
vent the system to room pressure first. few drop of R134a or oil left over in the system. will not blow up ur engine, dont worry.
Trending Topics
Seeing as how an inch of mercury is a hair over two pounds ,14 pounds of vacuum would effectively be 28.5 inches of vacuum. If his apparatus could pull that and after a period of time he could shut it down and maintain vacuum I see no reason it would not work. Correct me if I'm wrong.
Thanks everyone--good info. and questions
Tntech--i found a vac some guy who knows another guy has one.
But I need to know that same question b/ now my car is having that problem.
To your question now: it is for moisture--flush sys out/ flush fluid and air compressor. Hopefully contamination will also remove itself in the process
thanks--scott
thanks--scott
