Abs light blinks
Old Jul 15, 2011 | 10:46 PM
mzivkovic's Avatar
mzivkovic
Default Abs light blinks
I just changed abs module and master cylinder on my grand caravan 2006, but the abs light blinks? Before abs module replacement, the light was on all the time, but know blinks... What that can be?
Old Jul 15, 2011 | 11:35 PM
steak59's Avatar
steak59
did you diconnect the battery when you perform the repair?
there are codes stored in the Cluster (EVIC) when you replace the Cluster for "lost comm with ABS module". You need a scanner to erase it.
or try disconnecting the battery and touch the + and - lead together for few minute, see if it clears it.
Old Jul 16, 2011 | 02:05 AM
gentz's Avatar
gentz
You have to get the module programmed. You have to program in the tire size and possibly a few other things...Dealer or a private shop with the proper diagnostic tools will do. I just did one on a 2005 dodge durango, and had to program in the tire size and differential...
Old Jul 16, 2011 | 04:23 AM
mzivkovic's Avatar
mzivkovic
yes, the battery was disconnected during the abs installation. I will try to clear it as you said. Regarding programming ABS, I am sure that my mechanic didn't preform it. I bought a module from dodgeparts.com (if that is important) and he just replace it. When he scanned the codes, he said that he didn't receive any for ABS, so I was confused! It is logical that information such as tire pressure, size,etc needs to be imported. According to my mechanic, his code scanner is VERY GOOD AND EXPENSIVE , so I assumed that he can program it with this tool.
Old Jul 16, 2011 | 12:30 PM
gentz's Avatar
gentz
what scan tool does he have? I will tell you if it owrks or not. We have just about all aftermarket and The main OEM tools..and yes he has to program it size thats why the light is flashing with no codes...
Old Jul 16, 2011 | 12:44 PM
mzivkovic's Avatar
mzivkovic
He just called me. He has launch x431. It looks like windows pocket pc. Do you know that device? this is the pic ..
http://image.made-in-china.com/4f0j0...431-Diagun.jpg
Old Jul 16, 2011 | 04:53 PM
gentz's Avatar
gentz
Yes I know that device. He wont be able to do it.. You will need to take it to a certified shop with a witech
Old Jul 16, 2011 | 05:03 PM
mzivkovic's Avatar
mzivkovic
oh...ok... i am calling a dealer!! Thank you very much guys
Old Jul 16, 2011 | 05:36 PM
mzivkovic's Avatar
mzivkovic
I have one more question, Is it possible to buy some pc software and just connector for the pc -car? What kind of software-hardware do you recommend and is it possible to do this Abs settings with it?
Old Jul 16, 2011 | 06:22 PM
gentz's Avatar
gentz
Its gotta be certain diagnostic scanners only. I know the snap on verus does it($10K) And the Starmobile with a witech( OEM, dealer) if you were close to me I would do it for a six pack....only takes a few minutes at the most...
