2003 Dodge Grand Caravan blower motor replacement
Old Jul 22, 2011 | 08:11 PM
Jamcin's Avatar
Jamcin
Cool 2003 Dodge Grand Caravan blower motor replacement
I have a 2003 Dodge Grand Caravan V6 with no air, no heat no nothing. About a year ago I replaced the resistor behind the glove box and things seemed to work fine for a while. Then all of a sudden out of the blue my front blower wasn't working. I was able to tap on it and get it to work when I needed it for about several months and get it going but now nothing is working (coming on). I have been told that I need to replace the blower motor and possibly the resistor again. Is this right? If so then I can replace the resistor but need some help in replacing the blower motor. What would be the easiest way for me to go about replacing the blower motor without having to take it to a garage and pay the mechanic $600 dollars to get it done? Thought I read somewhere that the dash doesn't have to be removed. Is that right also? Any help would be appreciated. Not afraid to do the work myself and the cash to get it fixed ain't happenning during these hard times. Any photos, diagrams, or step by steps direction would be especially helpful.
Old Jul 24, 2011 | 06:00 PM
mfahey's Avatar
mfahey
When I had to replace the blower on our 2001, I went by what Alldata said to do which was to totally disconnect the dash and roll it to the rear, all to get at one lousy screw in the back(actually the front) of the blower housing. It was a total PITA especially when I read that the pros just cut the screw, remove the housing and replace the blower.
Do a search for blower replacement and you will get some more tips.
Old Jul 24, 2011 | 06:10 PM
RickMN's Avatar
RickMN
Yes, the book says to remove the dash. But you don't have to. Remove all the screws you can by pulling back the carpet. There will be one screw left you can't get to. But if you pop the hood and check around that area on the firewall, you'll find a screw that holds the heater box/fan assembly. Loosen that and you can pry the assembly out far enough to get the final screw out. This trick saves hours of time.
