99 caravan transmission codes
Old Jul 30, 2011 | 11:31 PM
kim shanklin's Avatar
kim shanklin
Default 99 caravan transmission codes
auto shop told me my transmission is out and i need a new one here are the codes they gave me 35-52-22-36-54-12 .
I have never had any problem with it until two days ago it just stopped moving in any gear .dose anyone know if it could be something elce?
1999 dodge caravan
3.3L v6 MPI All fulids are clean and full with no burnt smell
THANK YOU FOR ANY INFO .KIM
Old Jul 31, 2011 | 12:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Code 35 Loss of prime, 36 fault after shift, 52 gear ratio error in 2nd, 54 gear ratio error in 4th and 22 LR pressure circuit. Check the fluid level and also check for a transmission leak. If you don't have any leaks, The transmission may need to be overhauled or replaced.
