tires?
Old Aug 1, 2011 | 11:41 AM
bullheadpond's Avatar
bullheadpond
Default tires?
Have a2008 Grand caravan. I have Good year assurance fuel max tires. one of my rims has a slight defect that makes a slight vibration. i put it on the back and it is hardly noticable.
For this reason i can not put this tire on the front. i know the correct way to rotate the tires is in the book but can i rotate the left front to the right front and left back to the right back? i realize the tires won't last as long as if i did the correct way but i would like at least try and get a little more life out of the tires as i can not put the bad one on the front.
Back when i had rear wheel drive cars in the 80's they used to say if you rotate left to right you will bust a belt . Is this still true or was that just bs.?
PLease do not reply telling the correct way to balance tires. That is not an option here.
Thanks
Damone
Old Aug 1, 2011 | 12:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
I think that was just BS. Its still the same as is was back in the 80s.
Old Aug 1, 2011 | 12:18 PM
bullheadpond
Default mt
So in your opinion it should not do any damage to the tires if i swap the two front tires left tot right? H
ave about 6000 miles on the tires so far if that matters?
Old Aug 1, 2011 | 12:54 PM
vpnavy's Avatar
vpnavy
Here are a few articles on Tire Rotation...
      Old Aug 1, 2011 | 04:43 PM
      trophyslayer's Avatar
      trophyslayer
      are those Directional tires? if they are swaping sides will increase there wear since they will be going backwards
      I know my good year triple fortera treads are directional,
