Caravan BCM problem
Old Aug 5, 2011 | 09:06 AM
cornfield gy's Avatar
cornfield gy
Default Caravan BCM problem
My 2007 caravan a/c clutch won't kick in, door lock-unlock won't work and abs light on (dash). I think I blew the BCM, is there a fusible link or fuse for BCM?
Old Aug 5, 2011 | 07:19 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would try pulling the IOD fuse and push it back in after a few mins. If that doesn't work. Try removing the FCM ( front control module) and clean the connections. The FCM is in front of the PDC/IPM under the hood.
