Speed sensor help
Old Aug 29, 2011 | 02:25 PM
par5ntoo's Avatar
par5ntoo
Default Speed sensor help
Does anyone know where i can locate the pigtails for the sensors?? I am not fond of opening my wallet to the stealerships. Thanks!
Old Aug 29, 2011 | 04:03 PM
22mopar22's Avatar
22mopar22
sure would be nice to have a little more info? some vans potentially have 7 speed sensor (4 abs, trans input, trans output and passengers side axle speed sensor).
what is the price at the DEALER?
I don't think dealers steal anything. JY sure do. I needed a window regulator for a 99 durango. JY wanted $100, carquest and napa wanted $120, dealer had it in stock $80 brand new.
besides why do you need new pigtails. I've never seen one go bad.
Old Aug 29, 2011 | 04:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
As stated as before, Which sensor are you asking about?
Old Aug 30, 2011 | 12:20 PM
par5ntoo's Avatar
par5ntoo
Thanks for the welcome and replys.....sorry I missed the obvious ....they are for the Transmission input and output sensors.
I replaced them after the van went into limp mode and the speedo stopped working and throwing P0700. I noticed the output sensor plug had a nick in the wire right at the connector, I read that these were common failure points so i want to replace both of them while I have it apart.
Thanks again!!
oh and the dealer wanted 36.oo a piece for the repair connectors
Old Aug 30, 2011 | 05:33 PM
Cloak's Avatar
Cloak
I would'nt think that 36.00 ea is so bad considering u r getting OEM parts.
Some aftermarket electrical parts are'nt woth the box they come in
Old Aug 30, 2011 | 06:42 PM
par5ntoo's Avatar
par5ntoo
Default Update
Replaced the Output sensor connector and Viola!!!!!..........speedo works and tranny is once again at full glory.
Thanks again for the responses
Old Dec 1, 2011 | 02:19 PM
Nick 98's Avatar
Nick 98
So where did you find the parts you needed?
Old Dec 1, 2011 | 03:23 PM
Tizzy1's Avatar
Tizzy1
Dealer........2002 Caravan, input speed sensor........pn 05013948AA, $26.75. Output speed sensor......pn 05013950AA, $26.75. Comes with the plastic connector, terminals and wire, brass crimps and heat shrink tubing.
