2011 Grand caravan rough idle normal?
Old Feb 23, 2012 | 08:49 AM
falcan's Avatar
falcan
Smile
Hi to all, I’m new to the forum and happy to be part of this group, I have a 2011 GC Crew 5000K new purchase; I don’t experience this shudder; however I do feel the van shaking when I slowly reverse up an incline, and if you have your econo on in the city the trans will hard shift from 1st to 2nd aprox 17 kmh
Old Mar 12, 2012 | 11:04 AM
Tiny529's Avatar
Tiny529
Originally Posted by gentz
Tomorrow night I will setup the E-missfire, and my scope and scan tool and take some screen captures...Will post as soon as I have them all finished..
Hi! Just wondering if you found anything on this. We bought a 2012 GC last week and it's got less than 230 miles on it. I was shocked to feel the van shuddering at idle.
Old Mar 12, 2012 | 01:04 PM
gentz's Avatar
gentz
I had to hold off on this as i was at a point of trading in my 2011 GC. I kept it so I will start making some captures of missfires in the next few weeks. Seems it may be related to the cam phaser position. Will start testing in the next few weeks..
Old Aug 22, 2013 | 12:43 AM
raynist's Avatar
raynist
What did you find about this?
My 2013 with 1000k miles does this, did it on the first test drive also.
Old Sep 19, 2013 | 05:44 PM
papandkc2's Avatar
papandkc2
I just left my dealership after a discussion on the engine rough idle.
We checked 3 random new vehicles on the lot and they all had the same
rough idle problem and they are telling me that this is normal.i am in shock and i ,m not sure what to do now?
Old Sep 20, 2013 | 12:20 PM
DodgeCACares's Avatar
DodgeCACares
Papandkc2,
The dealer network is assisted and supported by Chrysler Canada to investigate the concerns submitted by our customers. As the manufacturer, there is not hesitancy on our part to comply with the warranty provisions in the case of an identified defect, however in the absence of a confirmed abnormality by an authorized dealer, we can not pursue any service under warranty.
If you would like your concerns reviewed, please feel free to PM me, if you are in Canada, or my US counterpart DodgeCares. You can also contact the Chrysler Customer Care Department at the phones numbers listed.
Canada: 1-800-465-2001
US: 1-800-992-1997
Old Sep 20, 2013 | 11:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
What I do is hook up my laptop and go on a road test and take a snap shot of any misfires. check TSB and star cases. Then either start a star case or fix the problem. So ask the dealer to do the same thing.
Old Sep 25, 2013 | 10:48 AM
rfielder's Avatar
rfielder
My 2011 DGC with 50,000km idles very, very smooth. In fact, I have once or twice had to check the tach to verify that it is running.
HOWEVER - this engine recently had both cam phasers replaced, as well as a "couple" of rocker arms that were worn. Prior to that work, I am not sure it was idling very smoothly. At times, it ran like a nightmare waiting to die.....
To my mind, the other reports in this discussion may be indicating that Chrysler has an issue with this engine that is not severe. Yet.
Old May 5, 2017 | 09:43 PM
Kendosmurf's Avatar
Kendosmurf
2011 dodge caravan running rough at idle and stop sign chugging on acceleration Kendosmirf 2 minutes ago
Best Answer
Check the valve in back of engine theres a hose that runs from it to the side of air intake i pinched the rubber part where it connects to the air intake manifold and all my problems disappeared. At the time i pinched the hose for a few seconds by hand my van was idling rough but when i let go the rpms picked up and van was running smoothly and has been ever since neighbor who is an retired mechanic thinks the valve was stuck which was giving me lean codea and random misfires due to improper mixtures. I had jeard a hissing noise coming from that side of the engine and a whoosh in the intake when i hit the gas but since they have both disappeared cant remember what the valve was called off hand
Old May 5, 2017 | 09:47 PM
Kendosmurf's Avatar
Kendosmurf
Originally Posted by Montrealfireguy
Ok so I tried without the ac or eco mode on this morning and I don't notice any improvement, still having the occasional stumble. If it isn't normal it sure seems like a common problem as per the other posts. I'm anxious to hear what gentz comes up with.
Best Answer
