2008 caravan problem
Old Sep 20, 2011 | 01:31 PM
JAMES RUSSUM's Avatar
JAMES RUSSUM
Default 2008 caravan problem
PROBLEM with 2008 caravan it is turning my wipers sprayer horn and lights on even when the car is off no keys in it have to disconnect the battery to stop it been to the dealer twice seem like they cant find the problem telling me i lossing the code when disconnecting it they are always close when this happens anybody else having this problem or solution ????
Old Sep 20, 2011 | 01:35 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
When this happens, do your windows work? Too bad you're not in TN...lol
Old Sep 20, 2011 | 02:05 PM
Tizzy1's Avatar
Tizzy1
found something that might help, it might not.
Symptom/Vehicle Issue:
Intermittent Loss of communication on Interior High Speed Bus, IHS, Bus. Cluster warning lights may be on, windshield wipers or head lights may be on and cannot be shut off. Vehicle may have bus fault codes.
Discussion:
If the vehicle is experiencing any of the above conditions, check for an IHS bus issue. Inspect the harness in the power lift-gate and motor area.
1. Monitor the IHS bus voltage with a DVOM and or monitor ECU topology view with a scan tool while moving the wiring in the subject area. If change or fluctuation occurs view and repair the failed area, connecter or harness.
Old Sep 20, 2011 | 03:19 PM
JAMES RUSSUM
Yes the window works
Old Sep 20, 2011 | 03:21 PM
Cougar41's Avatar
Cougar41
That's the trouble with bus systems. A problem in one area can show itself in another. Sliding door harnesses causing irratic instruments and now this.
Old Sep 20, 2011 | 03:37 PM
TNtech's Avatar
TNtech
There are 4 or 5 common trouble areas on these for the CAN IHS BUS.
James, a good dealer will have someone who knows where to start looking. I kind of agree with them though...don't erase the codes with a battery disconnect anymore. At least they'll have an idea of where to go to first and save you a little dough.
Old Sep 20, 2011 | 04:57 PM
JAMES RUSSUM
THANKS THERE IS A RECALL ON THE SLIDING DOOR HARNESS i WILL BE CALLING THE DEALER TOMORROW TO TAKE CARE OF THIS HOPEFULLY IT WILL FIX THE PROBLEM i WILL LET YOU KNOW VERY HELPFUL THANKYOU
Old Sep 21, 2011 | 06:56 PM
Cougar41's Avatar
Cougar41
Discussion:
Tizzy. Is this part of a TSB?
