Injector Circuit Malfuntion
Old Sep 26, 2011 | 09:48 PM
alydar66's Avatar
alydar66
Default Injector Circuit Malfuntion
Hi, I have a 1998 Caravan with a 3.0 engine and have a problem with a Injector Circuit Malfuntion trouble code on only 1 injector. I have replaced the injector and checked all wiring and connectors. I used a noid light on the driver output from the PCM and dicovered that the light did not flash for the injector that I have the code for. So I assume I have PCM thats not sending a signal to the injector. Can I also assume that the PCM is the problem or can something else cause this problem? If it is the PCM, could getting it reprogrammed solve the problem or do I have to repace it? Thanks for any help anyone can offer.
Old Sep 26, 2011 | 11:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would ohm test the injector wire to make sure you don't have a open or shorted wire.
Old Sep 27, 2011 | 12:11 AM
alydar66's Avatar
alydar66
Yes i did that already. I check resistance from the connector to the injectors and from the connector back to the PCM. There are no shorts or no opens from the PCM connector to the injector. So if there is no signal coming from that one injector driver does that mean the PCM is bad?
Old Sep 27, 2011 | 12:26 AM
master tech
Thats correct. You may have a bad driver in the PCM.
Old Sep 27, 2011 | 12:49 AM
alydar66's Avatar
alydar66
Thank you
Old Sep 27, 2011 | 02:28 PM
gentz's Avatar
gentz
I have seen several injector drivers go bad by bad injectors....So now off to replace the ecm.....
Old Aug 12, 2012 | 08:49 PM
D. Rhett's Avatar
D. Rhett
I have the same problem with an '02 caravan. Found battery voltage at PCM pin. Whats up with that ?
