1997 Dodge Caravan
Old Sep 27, 2011 | 12:57 AM
Flatbedder's Avatar
Flatbedder
Default 1997 Dodge Caravan
I have in my possession a formerly good running dodge caravan. I have been running it to keep the battery charged but while it was running it was turned off and now will not start. when I turn the ignition a clicking sound results. It's coming from somewhere inside the engine and the starter motor won't run. I tried jumping it but that didn't work either.
Any ideas/tips/help?
Old Sep 27, 2011 | 08:02 AM
22mopar22's Avatar
22mopar22
put in a new battery?
battery cables clean and tight?
have full voltage at the battery (12.6v)
check the starter?
Old Sep 27, 2011 | 11:50 AM
Flatbedder's Avatar
Flatbedder
The battery is very new but I will try cleaning the cables. Baking soda and water right?
Everything was working fine until it got shut off. I couldn't start it 2 seconds later. :-/
Old Sep 27, 2011 | 03:18 PM
22mopar22's Avatar
22mopar22
don't you have any friends/neighbors/co-workers that know anything or know someone that could have a look and see what's up?
Old Sep 27, 2011 | 11:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Try recharging the battery and check the charging system.
Old Sep 28, 2011 | 02:55 PM
Flatbedder's Avatar
Flatbedder
Thank you. Will do.
Old Sep 30, 2011 | 02:25 PM
Flatbedder's Avatar
Flatbedder
Yeah. Maybe I can convince him to let me borrow his computer reader. Hmmm.......
Old Jan 21, 2012 | 11:37 AM
tufftimes1's Avatar
tufftimes1
Default 1997 caravan base Starting issue.
I have a similar problem. I used the car last tues evening for work. Everything was fine. In the morning when I tried to start it all I got was a clicking under the dash somewhere. The clicking remained even when I turned the key off. Mu 1998 Neon did this same thing as well but I had just taken it off the road and never looked at it. I charged the battery for about a day and a half until I needed it again. I got the same thing. Putting it in neeutral does not help. Any ideas???
Owen
Old Jan 21, 2012 | 02:31 PM
maxbaby's Avatar
maxbaby
If you 've followed the above suggestions, then you need to run the codes. No way other than to guess with the limited information provided.
Old Jan 21, 2012 | 03:57 PM
Cougar41's Avatar
Cougar41
Have you tried jump start it using jumper cables? Head to the nearest parts store and have them do a load test on the battery. They are usually free. Other than that verify the battery and starter connections are clean and tight. Don't just look. Loosen and re-tighten.
BTW -You won't get any relative codes in a no crank situation.
