Tranny Codes? 2004 Dodge Gr Caravan SXT
Old Oct 6, 2011 | 10:15 AM
Wheelz1's Avatar
Wheelz1
Default Tranny Codes? 2004 Dodge Gr Caravan SXT
had lube and oil etc. changed Monday, Tuesday while I was driving, I noticed it shifted 2 times a lil funny but nothing major, then check engine light came on, took to a CAA garage and they found 2 codes
P0700 X2 (trans control circuit) and P1776 LR (solenoid stuck rear) - test drive showed shifting normally - they resect the codes and has not come back on yet. Mechanic says a tranny fluid and filter may fix it as it may have been a small bit of dirt that tripped the solenoid? Would that help? Really cannot afford to get into a re-build so hoping nothing serious?
any advice?
Thanks in advance!
has 164,000 KMS on it
Old Oct 7, 2011 | 05:42 AM
papaduck's Avatar
papaduck
I had something similar happen a few years ago. Shut the van off and have never had the problem arise again. Could have been a bug in the computer and after shutdown it reset it didn't come back.
I would say drive it and if it doesn't come back, feel lucky.
Old Oct 7, 2011 | 11:36 AM
master tech's Avatar
master tech
Site Moderator & Tech
Have you had the transmission service yet? It maybe the solenoid pack that got some debris in the screen and then move to where it started shifting again.
