2008 Caravan rough shift when cold
Old Oct 7, 2011 | 02:53 PM
NFSPD's Avatar
NFSPD
Default 2008 Caravan rough shift when cold
I just acquired a 2008 caravan. When its cold the shift from 1st-2nd and when slowing 2nd-1st is rough as soon as its warmed up after driving a bit its perfect. What would cause this and any possible fixes.
Thanks
Old Oct 8, 2011 | 12:39 AM
dushash's Avatar
dushash
What kind of oil do you have in the transmission and is it clean? In general almost every car (unless it's a CVT) would shift rough on cold. Of course rough doesn't mean any really uncomfortable shifting.
Old Oct 8, 2011 | 01:46 PM
NFSPD's Avatar
NFSPD
It has as far as I know whatever the factory recommends. I haven't changed it but it looks pretty good.
Old Oct 8, 2011 | 04:04 PM
lxman1's Avatar
lxman1
Site Moderator
It may just need a reflash of the computer. How many miles on the van?
Old Oct 9, 2011 | 02:22 PM
NFSPD's Avatar
NFSPD
It has 90K on it currently. Once you drive for a few minutes its fine. But when its cold if you are going slow or come to a quick stop it seems to have an issue and shifts harsh.
I have been reading alot and i am debating taking to the dealer for a drain & fill and a reflash
Old Oct 9, 2011 | 09:10 PM
vabear's Avatar
vabear
Default Cold Shfting Issue
I have seen this happen when fluid other than ATF+4 was used, such as MERCON or DEXRON, I would try a fluid change as first step.
