thump while turning at slow speed
Old Oct 24, 2011 | 05:53 AM
papaduck's Avatar
papaduck
Default thump while turning at slow speed
My van has just developed a slight thump while making a hard turn at slow speed on the driver side. Does not do it every time, just once in a while. It does not do it over bumps. I know it is not the sway bar bushings or linkage haveing just replaced them. I have not looked at it yet but would like to know just what to look for when I do.
Old Oct 24, 2011 | 10:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
My first guess would have been a loose tire, brake rotor, wheel bearing or cv joint.
Old Oct 25, 2011 | 08:27 AM
papaduck's Avatar
papaduck
The wheel and brake rotor are tight. The cv joint and wheel bearing should give other signs if going bad, but I will check them.
Can the spring in the shock tower slip and give this kind of bump?
Old Oct 26, 2011 | 12:23 AM
master tech
Sure it could.
Old Nov 5, 2011 | 04:13 PM
papaduck's Avatar
papaduck
Just to let you know.
The driver side tie rod end had a very small amount of play, could not see any movement but could feel it as the wife rocked the steering back and forth. It is now fixed.
Old Nov 5, 2011 | 06:19 PM
steak59's Avatar
steak59
Strut bearing?
Old Nov 5, 2011 | 07:50 PM
papaduck's Avatar
papaduck
Not the strut bearing.
The ball joint at the outside end of the tie rod next to the wheel. While turning at slow speed the tire was being turned like it was not rolling and when the steering was turned in the oposite direction it would thump, but not every time. There was just a little slack in the ball joint, not enough to see, I could only feel it when holding the joint.
