help me !!!!!!08 caravan going crazy
Old Nov 30, 2011 | 08:26 PM
helpmeplz's Avatar
helpmeplz
Default help me !!!!!!08 caravan going crazy
parked overnite....opened passenger sliding door, put something inside, closed door, locked and went back inside.....a few mins later i heard the horn going.......1st thought was the alarm, so i went back out to turn off....to my surprise....the horn was constantly going, wipers going, washer spraying.....had to use manual key to get in it.....tried to start and nothing......all the above still going..... the only way to stop was to disconnect the battery terminals............please help!!!!!!!!!!!....no warrenty that i know of.....i am the 2nd owner......sliding door recalls? total bus failure?....i have read about a few recalls...dont know if any apply.......any ideas?...i will be here till bout 11 EST. if you have any ?'s plz just ask me....this is my moms car...and i am a HVAC tech......so i know how owners can be.....just dont want her to pay an arm and a leg if not needed, but already expecting at least 1 arm.......have no problems repairing what is wrong......will be taking it tomorrow to dealer........
Old Nov 30, 2011 | 10:19 PM
If you re-connect the battery does it continue being insane?
Aside from trying that, I haven't a clue......
Old Nov 30, 2011 | 11:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
Here is the recall for the sliding doors.
Safety Recall K14
Power Sliding Door Wiring
2008-2009 (RT) Dodge Grand Caravan and Chrysler Town & Country
NOTE: This repair procedure applies only to the above vehicles equipped with power sliding doors (sales codes JRA and JRB).
The right and/or left power sliding door wiring harnesses on about 284,000 of the above vehicles may chafe on the sliding door hinge when operating the sliding door. This could cause the sliding door latch to overheat and cause a fire inside the sliding door.
The power sliding door wiring harness and the drive motor wiring harness must be inspected for damage and repaired/replaced as necessary. The two harnesses must then be tie strapped together and routed under the sliding door weather strip and a tab/wedge installed on each sliding door lower hinge bracket.
Models IMPORTANT: Some of the involved vehicles may be in dealer used vehicle inventory. Dealers should complete this recall service on these vehicles before retail delivery. Dealers should also perform this recall on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
