Oil Pan Gasket Replacement on 2004 3.3
Old Dec 4, 2011 | 06:30 PM
dorough's Avatar
dorough
Default Oil Pan Gasket Replacement on 2004 3.3
I need to replace this gasket. I've crawled under the van and poked around for a few minutes to see what was involved. It looks like all but maybe 2 or 3 of the pan bolts are easily accessible. But those few are obstructed by a flange/mount of some sort. I know there's a plate and rubber seal on the back of the engine that needs to be loosened, but I'm talking about the piece of metal to the rear of that. Can somebody boil this down for me and let me know what's involved? I'm hoping I can do this job quickly and won't have to go to any major trouble to get that sucker off. Thanks in advance!
Old Dec 6, 2011 | 11:33 AM
dorough's Avatar
dorough
Anyone? Bueller? Bueller?
Old Dec 8, 2011 | 12:19 PM
scotter5's Avatar
scotter5
Hey. I will list 3 links below for you. They will help. One of them is a video, although it is a 2.4 engine, I guess. The guy in video is good. I have seen him in other videos. He's interesting and talented. I live in ft lauderdale, fl. If you live close i would love to volunteer together and take it off. i like working on cars and learning. all though, i am a novice.
http://www.youtube.com/watch?v=N5z9My6i5Iw
https://dodgeforum.com/forum/dodge-c...-question.html
http://forum.chryslerminivan.net/sho...l-pan-05-06-07
Sure hope this helps. And again if you live around here let me know.
Old Dec 10, 2011 | 02:17 PM
lovvorn's Avatar
lovvorn
Default Mileage & & Scheduled Maintence !!
Hi , These fuel injected engines today will not leak oil today due to good design !! If youre leaking oil your P.C.V. valve is stopped up due to poor maintence or wear due to high mileage !
Your compression rings are not sealing resulting in piston compression blowby there for pressurizing your the interia of the engine causing the oil leaks due to compression blow by .
If you are leaking oil put a oil pad under your leak till you get new piston compression rings installed !! My Thoughts Lovvorn
Old Dec 10, 2011 | 03:11 PM
scotter5's Avatar
scotter5
Hi. Are you saying the pcv valve could be causing the leak or is it the secondary problem caused by the compression reings having been worn down? Just trying to learn.
