2002 Caravan Check Engine Light Need Help Turning It Off
Old Jan 22, 2012 | 08:31 PM
DJboutit's Avatar
DJboutit
Question 2002 Caravan Check Engine Light Need Help Turning It Off
I have a 2002 Caravan with a cb radio setup I have check engine light on now I know it is nothing when I use the cb radio it sets a code how would I remove this code?? In the next few days I need to get a inspection I can not pass with the check engine light on. I have had this problem before cb radio sets a code that is nothing I just need it turned off I do not want to pay $50 every time to cb radio sets a code in the computer to get it turned off what can I do??
Old Jan 22, 2012 | 09:06 PM
maxbaby's Avatar
maxbaby
If you don't have a code reader, try disconnecting your battery for a half hour.
Old Jan 22, 2012 | 09:13 PM
DJboutit's Avatar
DJboutit
That might work I will dissconnect the power for like a hr or 2
Old Jan 23, 2012 | 03:57 PM
DJboutit's Avatar
DJboutit
I unpluged the power cable to the batter for 90min the code is still there now what
Old Jan 23, 2012 | 04:31 PM
Cougar41's Avatar
Cougar41
What code is turning on the light? Disconnect the CB radio then try the reset again.
Old Jan 23, 2012 | 05:04 PM
DJboutit's Avatar
DJboutit
I do not have any idea I do not have a code reader
Old Jan 23, 2012 | 06:53 PM
Cougar41's Avatar
Cougar41
Cycle the key from off to on three times within 5 seconds leaving it on (not start). The code should be displayed on the odometer. If that doesn't work head to an AutoZone or the like and have them do a free code scan.
Old Jan 27, 2012 | 02:54 PM
DJboutit's Avatar
DJboutit
I took my car to the shop to see why check engine light is they just called and said there is a conflict with the pcm will reset the code then I will have to drive it 100 miles. If the check engine ligt comes on agin I will have to take it back & they will replace the pcm if not I have to go get it inspected.
Old Jan 27, 2012 | 05:01 PM
Cougar41's Avatar
Cougar41
AutoZone has PCMs for around $300. Same for Autocomputerexchange.com. You send them your VIN #, they program the new one, you install it.
