electical problem
Old Feb 13, 2012 | 06:24 PM
erdenur's Avatar
erdenur
Default electical problem
I have dodge grand caravan 2002 and 3.3 engine last week while driving electric going off and coing on again in1-2 second whe I hit bump or something. I replace battery and today replace fuse box still having troble on that. Do you have any idea please what should I do .
Thanks
Old Feb 14, 2012 | 01:01 AM
ZJWilly's Avatar
ZJWilly
Welcome to Dodgeforums. There are many subjects on this issue. We need you to be more specific on the electrical issue. I had a similar issue with the cluster not working. It turned out to be a wire corroded at fusebox in engine compartment. Best is to find the connector to the device having issues and test the voltage.
Good Luck and Keep us Posted!!!!
ZJ....
Old Feb 14, 2012 | 10:03 AM
erdenur's Avatar
erdenur
It is not only display, Its heater stops, brake is on and all needle on display going end and all lights of coming down again, car is shaking , radio going off and on in second. I replace fuse box yesterday , adn i m thinking to replace ecm(computer) with used one. Is battery makes this problem or, alternator, ecm or only bad connector .? thanks
Old Feb 14, 2012 | 12:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you lift up the PDC/IPM and check all the connection?
Old Feb 15, 2012 | 09:54 AM
ZJWilly's Avatar
ZJWilly
Master tech has very good advice(as always)..Check all your connections before spending any money...ECM and BCM are not designed to faulter.. Swapping either of these can cause more harm then good so be careful..identical model and serial#'s mean nothing as they are vehicle specific..You will need to get a dealer to reprogram them with no guarranty it will solve your issue...irratic electrical issues are usually a sign of faulty wiring...
ZJ
Old Feb 22, 2012 | 08:10 AM
erdenur's Avatar
erdenur
Yes couple times with friend I removed battery and cleaned with air pressure all sockets(plugs) . I do not know what else i have to check. last days engine light came on but it was code p1495 , I think it is no cause electrical problem ? I was replaced my heat resistance last month problem start after 2 weeks from replaced day. Now I m just driving like that but sometimes its scary. Thanks who trying to helping me.
Suincereley
Ercan
Old Feb 22, 2012 | 05:07 PM
Cougar41's Avatar
Cougar41
Try disassembling the IPM. If there is corrosion on the circuit board replace the IPM. The IPM is a corrosion magnet. It's been driving 4th generation van owners nuts for a decade.
Old Feb 28, 2012 | 04:00 PM
erdenur's Avatar
erdenur
I solve the problem. thanks everybody. My friends came and look at it , he add a cable from battery negative to the ground of car and its solve all problem. But if anybody has wiring diagram from negative to ground original please send me a picture or a link i will be happy. He just fix it temporary need wire diagram to fix completely . Thanks everyone who try to help
Old Mar 1, 2012 | 01:38 AM
ZJWilly's Avatar
ZJWilly
Glad you finally got it fixed...This should help...
