2003 Caravan-Sound from transmission as I slow down...
Old Feb 14, 2012 | 02:51 PM
kanny's Avatar
kanny
Default 2003 Caravan-Sound from transmission as I slow down...
A clunk sound comes from the transmission when my 2003 Grand Caravan slows down... could you please tell me what could be wrong?
Old Feb 14, 2012 | 07:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Has any work been done on the transmission? Could be a loose motor mount, drive axle nuts or the clutch volume is too high in the transmission.
Old Feb 14, 2012 | 09:37 PM
kanny's Avatar
kanny
no work has been done on the transmission. When I put it on D (drive), it makes a clunking noise, and when i put it on 3, it does not make a noise...
Old Feb 14, 2012 | 10:53 PM
master tech
I would check the axle nuts (165 ft pounds) and the motor mounts too.
Old Feb 15, 2012 | 08:43 PM
kanny's Avatar
kanny
I just checked that and nothing is wrong with the axle nuts OR the motor mounts... when I am cruising on 70+km and I slow down to 20km-30km, it makes a clunking noise. Thanks for your help.
