Air bag light stays on
Old Feb 14, 2012 | 08:36 PM
jayc21a's Avatar
jayc21a
Default Air bag light stays on
I am getting a SRS 39 code when I check my codes in my 2002 Caravan 2.4l engine. My airbag light stays on all the time. I am trying to figure out what this could be. This all happened when I changed the Transmission out. It also made my check eng light come on. I had to replace the Computer in the van. I cant get the airbag light to go out? What could it be the problem? Any help would be Great.
Old Feb 15, 2012 | 02:42 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The information from my books don't show a code 39 for the SRS system, You may need a scanner to read the code and post. I know the DRB3 doesn't show codes, just what code means.
Old Feb 15, 2012 | 03:19 PM
Tizzy1's Avatar
Tizzy1
If it happened after you put the PCM in the vehicle, you probably have a VIN mismatch issue. Alot of modules store the vehicle's vin and if they don't match, the light comes on.
Old Feb 16, 2012 | 04:11 PM
jayc21a's Avatar
jayc21a
It shows the SRS code 39 even before I changed the PCM. The Vin# is correct in the PCM. Is there a dodge DRB3 book of codes that I can look up?
Old Feb 16, 2012 | 04:17 PM
jayc21a's Avatar
jayc21a
Is there any sensors on the front bumper area? I have swapped out the Clock spring before I changed the PCM didn't change anything.
Old Feb 16, 2012 | 10:49 PM
Cougar41's Avatar
Cougar41
Info on the net is slim to none on a code 39 but I did find this. According to this a code 39 flags a problem with the driver's seat belt tensioner. It's a bit cryptic but the info is there: http://www.justanswer.com/dodge/62un...dge-grand.html
