Need fix on Transmission problem
What I meant was the 3 speed transmission has a gasket between the filter and valve body. If the holes are not lined up to the correct holes, You will loose fluid pressure to all gears or burn up the transmission. The 4 speed transmission has an o-ring and will do the same thing if its not install correct.
