1999 Keyless Control Module
You need to run your vin number to find out if the van is equipped with the module and if you add one you need to make sure it has the wiring harness plug already installed in order for a direct plug in. The harness is located under the top right side of the dash and I wasn't comfortable trying to pry up on it to find if my van was equipped with the harness but my vin said it didn't come with a module so I'm just using the keys...it's a bit unconvienant but I didn't want to end up cracking the dash either.
INSTRUMENT PANEL TOP COVER
REMOVAL
- Remove A-pillar trim. Refer toBody, for A-Pillar Trim Panel Removal and Installation.
- Using a trim stick, disengage clips holding rear edge of top cover to instrument panel, Instrument Panel Top Cover NOTE: The Instrument Panel Top Cover may be hard to unsnap from the instrument panel. Be sure not to mar, scuff, or damage the instrument panel pad.
- Disconnect wire harness from message center.
- Pull top cover rearward to disengage hooks holding front of top cover to instrument panel.
- Remove top cover.
