2005 caravan intermittent grinding noise
Old May 3, 2012 | 10:43 PM
onetruelovie's Avatar
onetruelovie
Default 2005 caravan intermittent grinding noise
Hello! I'm new so I appologize if this question has already been asked.
I have a 2005 Dodge Caravan SXT with 62,000 miles. Only repair we ever needed was a bad EGR valve.
3 weeks ago as I was pulling into a parking lot I heard a very loud grinding noise coming from the front of the car, drivers side. I stopped the car and the noise stopped. Tried to reverse and got a "shudder". Put the car back into Drive and the loud grinding sound started again. Pushed on the gas and once it got up to about 15mph the noise stopped.
This has happed about 5-6 times in the last 3 weeks. Not everytime we drive it, whether the engine is warmed up or cold. Inclines do not seem to make a difference. Also, it does it in Neutral too.
We have taken it to a general mechanic who drove it several times, couldn't find anything wrong and didn't hear the noise. Transmission fluid is red, no smells. No check engine light and no codes.
2 transmission places kept the van overnight, drove it several times. But because it is intermittent, they were unable to hear the sound. Yet they told us we probably needed a new transmission. Does this sound right? Has anyone heard of this happening before? Even in Neutral?
I really appreciate any advise, we are at a loss! Thanks so much for your time.
Old May 5, 2012 | 04:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Unless they can verify the problem, I wouldn't start replacing any parts. One of the problems i have seen is the exhaust pipe hitting the body on the passenger side sliding door area. And it wouldn't make the that type of noise all the time either.
