Timing Gasket Leak
Old May 16, 2012 | 11:29 AM
pinguy's Avatar
pinguy
Default Timing Gasket Leak
Anybody out there experience a cracked timing cover gasket? I had my 3.8 apart March 2011 because it threw a connecting rod bearing. In October of 2011 the timing cover gasket developed a leak around where the oil pump sits. After taking it apart I noticed several cracks that went through the gasket. I replaced the gasket, but did not use any sealer because my Alldata guide said not to. I now have another leak in the same spot. Has anyone else seen this kind of a problem?
Old May 17, 2012 | 10:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
Yes, In all the repairs i do on the timing covers. I will use ultra stick, which is a glue. I would replace the timing cover if you continue to have any more leaks.
Old May 18, 2012 | 06:53 AM
pinguy's Avatar
pinguy
Thanks for the info. I will try that
