Power Window and Door
Old Jun 12, 2012 | 11:12 AM
Dodge2008's Avatar
Dodge2008
Default Power Window and Door
My passengers side power window on my 2011 Dodge Grand Caravan goes down fine until it gets a 1/4 of an inche from the bottom and then stop and goes a tiny bit further very slowly then stops completely. Any idea if I can fix this myself?
Also, my drivers side power sliding door has a clunk noise when the body flexes. Sounds as if it is off the track or lose but opens and shuts fine....any ideas?
thanks,
Old Jun 14, 2012 | 11:01 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is the van still under warranty? If it is, I would have the dealer look at the problem.
Old Jun 27, 2012 | 11:37 AM
Dodge2008's Avatar
Dodge2008
master tech....teh dealership diagnosed the noise as coming from the rear shocks i believe. He said a TSB was out about the noise. I am not sure if that will be it or not though.
The window the tech said appears to be getting caught on something. At first he said it was a smart motor and needed to learn when it was all the way down. But his "reprogramming" didn't work. He said not to worry about it and that it is fine. I can't imagine it is ok for the window to stop going down approx a 1/4 inch from the door and then needing to be pushed down the rest of the way....thoughts?
thanks
Old Jul 19, 2012 | 09:20 AM
silverfun's Avatar
silverfun
Default Power Windows
Mine will have that exact same behavior if I use the window rolldown feature from the remote. It works great if using the buttons inside the van (with the engine running) I noticed with the engine not running it will do this also using the switches inside.
