Speed sensor rubbing
Old Jun 13, 2012 | 08:03 PM
misinformed's Avatar
misinformed
Default Speed sensor rubbing
hey people new here, and hello, I have looked through some old post here but could not see one with my problem. Well here it is, I have changed the output sensor twice in the last year on a 2000 caravan 604 trans because it seems to be rubbing something on the inside and wearing the plastic away on the sensor. then become inoperable. then engine light then code you guys know the routine. But anyway why is this happing.
Well also tonight i put a gasket on the new sensor to hold it out a little bit to keep it from wearing. It still seams to run fine and shift fine and no codes after i done this. Any information on this would be great or just tell to that was a stupid idea, i'm ok with that Thanks
Old Jun 14, 2012 | 03:20 PM
misinformed
Hello and welcome to the forums missinformed!
Well i think you are on the right track about shimming the sensor but i can not tell you why it is happening or if the shimming will last. Maybe some others here might of had this happen. Good luck misinformed.
Old Jun 14, 2012 | 11:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If the sensor is getting damage from the inside of the transmission, then the problem is inside the transmission. You can not shim output or input turbin sensors. You can adjust the air gap for camshaft and crankshaft sensors. I would recommend to tear the trans apart and inspect why the sensor is getting damage.
Old Jun 15, 2012 | 12:07 PM
misinformed
Thanks for the input, I will look into it.
Old Jun 22, 2012 | 10:46 PM
mbrahmer's Avatar
mbrahmer
I'd say the rear planet assembly is worn to the point it moves enough off center to hit the turbine speed sensor.
Old Jun 24, 2012 | 01:20 PM
master tech
I would agree, thats why recommended a tear down.
Old Jun 25, 2012 | 12:23 PM
misinformed
Ok thanks
