P0304 Cylinder 4 misfire
Old Jul 12, 2012 | 10:47 AM
RedOctober1971's Avatar
RedOctober1971
Default P0304 Cylinder 4 misfire
My 2001 Caravan is starting and idling rough. This started only a week ago and I have since done an oil change with new oil and air filters, replaced all plugs, wires and the ignition coil. I disconnected the battery for a couple of minutes to try to reset the computer. It's still having the problem. Initially, I couldn't even get the car to start but after replacing the plugs, wires and coils, it starts fine, just runs rough. I am also smelling a small amount of gas in the exhaust.
If anybody has any ideas about what this might be, I'd appreciate it. I have broken too many nails trying to get this thing running right. I am out of ideas!
Old Jul 12, 2012 | 11:05 AM
Cougar41's Avatar
Cougar41
May have an injector on the fritz or dropped valve causing low compression. Are you getting spark and fuel and injector pulse at #4?
http://www.obd-codes.com/p0304
Old Jul 13, 2012 | 06:55 AM
RedOctober1971
Yes, I am getting spark but haven't checked beyond that. The odd thing is, I had changed the plugs and tested - #1 and #4 were misfiring. I changed the wires and the problem with #1 went away. The old plug in the #4 spot seemed particularly fouled when I removed it but, then again, I have no idea when the last time might have been that these things were done.
How would I go about checking the injection and ignition pulse, as you recommended?
Old Jul 13, 2012 | 08:30 AM
HammerZ71's Avatar
HammerZ71
Was there any milky color to the oil when you changed it? I'm thinking maybe a head gasket tear around cylinder #4...
Old Nov 4, 2012 | 10:04 PM
SilverZero's Avatar
SilverZero
So where did you end up on this? I have a P0304 code as well, just under 100k on a 2001 SE 2.4L. Just replaced the plugs and wires this weekend hoping it would be that easy, still getting the code as well as a flashing light sometimes at idle (rough idle, intermittently). Should I move on to a new coil, or do some other diag's first?
Old Nov 5, 2012 | 08:01 AM
RedOctober1971
I should have posted earlier. Sorry. Turned out that we had a blown head gasket. After trying to fix various things, we gave up and bought a new car. This one just wasn't worth any more time of money invested.
