2000 GC 3.3 water leak
Old Jul 20, 2012 | 01:40 PM
Chazwel's Avatar
Chazwel
Default 2000 GC 3.3 water leak
Is the weep hole above the heater hose inlet on the water pump? that is where I have a leak. Thanks.
Old Jul 20, 2012 | 10:08 PM
lovvorn's Avatar
lovvorn
Default Water pump ?
It's the only weep hole I know . Bad seal !
Old Jul 21, 2012 | 01:59 PM
Chazwel's Avatar
Chazwel
I am thinking bad water pump. I will see tomorrow when I change it out.
Old Aug 2, 2012 | 12:18 PM
Chazwel's Avatar
Chazwel
It is not the water pump leaking. What is the water pump bolted to? It is leaking on top where the radiator hose attaches. Looks like a bunch of stuff to take apart to get to it.
Anyone?
Old Aug 2, 2012 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
It maybe the 5/8 heater hose that goes between the intake manifold to the timing cover on the back side of the water pump. Its about a foot long. Its not the bad to replace.
Old Aug 3, 2012 | 07:40 AM
Chazwel's Avatar
Chazwel
Thanks, I will take a look at it and report back.
Old Aug 3, 2012 | 10:31 PM
Chazwel's Avatar
Chazwel
That is what it is Master. The metal "tit" on top, that the heater hose connects to is rusted out. It came right out of the hosing. Does anyone know if anyone sells this part? It is not threaded in to the housing, it is just a slip fit. If I can't find a part, then I will have to engineer something.
TIA.
Old Aug 3, 2012 | 11:50 PM
master tech
The part is called a nipple and it is a press fit. The part number which is a mopar number 4621652AC, I would buy two.
Old Aug 4, 2012 | 12:33 PM
Chazwel's Avatar
Chazwel
Dealer has 1 @ $12. Will go pick up and install, let everyone know how it goes. Thanks M.
Old Aug 7, 2012 | 07:49 AM
Chazwel's Avatar
Chazwel
Everything went fine. Got the nipple, hammered it into the housing hole, reconnected everything. No leaks. Went ahead and flushed cooling system and refilled with coolant. Thanks for the help everyone.
FYI- I removed the oil filter to gain access to the nipple from below. Alot easier.
