Please help 91 caravan
Old Jul 22, 2012 | 05:12 PM
solidkevlar's Avatar
solidkevlar
New Member
Default Please help 91 caravan
hello my dad has a 91 3.3l dodge caravan will not fire only fires on starting fluid it seams to have fuel presser as i pressed the button on the fuel rail and it spraid the firewall its like the injectors are not shooting fuel. the van does not even try to fire just cranks i thought it was fuel pump but like i said it shoots far
Old Jul 23, 2012 | 10:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you check to see if you have power at the ASD relay? Or have you check any fuses for the engine?
Old Jul 24, 2012 | 09:10 PM
solidkevlar
New Member
if it was asd relay wouldnt it not have spart to? but ill check and i did check the fuses
