drivers door power window
Old Jul 28, 2012 | 09:45 PM
pappyken's Avatar
pappyken
Default drivers door power window
Power window on 2005 caravan drivers side quit on me, how can I remove door panel and what should I look for, motor was installed less than a year ago. Mechanic that installed it is no help at all. Any help at all would really be appreciated. thanx
Old Aug 1, 2012 | 11:17 PM
master tech's Avatar
master tech
Site Moderator & Tech
REMOVAL
Remove the plug and remove screw attaching door pull cup to inner door panel.
Remove switch bezel and disconnect power window/memory switch.
Remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Remove screw holding door trim to door panel from behind inside latch release handle .
Disengage clips attaching door trim to door frame around perimeter of panel.
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle (INSIDE DOOR HANDLE LINKAGE).
Separate linkage rod from latch handle.
Disconnect the power door switch, courtesy lamp electrical connectors.
Remove front door trim panel from vehicle.
Then use a 12 volt test light and check for power on the up and down side on the connector. Or tap on the window motor. goes it go down, if yes. replace the motor and regulator.
