strut torque specs
Old Aug 3, 2012 | 06:36 PM
fs1's Avatar
fs1
Default strut torque specs
What are the torque specs for the pinch bolts and mounting nuts on a 99 caravan?
Old Aug 3, 2012 | 10:28 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
FRONT SUSPENSION FASTENER TORQUES
DESCRIPTION TORQUE
Strut Assembly:
Strut Tower Attaching Nuts 28 N·m (250 in. lbs.)
Steering Knuckle Attaching bolts 88 N·m(65 ft. lbs.) Plus 1/4 Additional Turn
Strut Shaft Nut 100 N·m (75 ft. lbs.)
Steering Knuckle:
Ball Joint Stud Nut/Bolt 145 N·m (105 ft. lbs.)
Disc Brake Caliper Bolts 41 N·m (30 ft. lbs.)
Wheel Stop 95 N·m (70 ft. lbs.)
Hub And Bearing:
Mounting Bolts 65 N·m (45 ft. lbs.)
Hub Nut 244 N·m (180 ft. lbs.)
Wheel Mounting Lug Nuts 135 N·m (100 ft. lbs.)
Lower Control Arm:
Lower Control Arm Pivot Bolt 185 N·m(137 ft. lbs.)
Lower Control Arm Rear BushingRetainer Bolt 68 N·m (50 ft. lbs.)
Stabilizer Bar:
Bushing Retainer Cradle AttachingBolts 70 N·m (50 ft. lbs.)
Attaching Link Nuts 88 N·m (65 ft. lbs.)
Front Suspension Cradle:
Body Attaching Bolts 163 N·m (120 ft. lbs.)
Reinforcement Plate AttachingBolts M-12 108 N·m (80 ft. lbs.)
Reinforcement Plate AttachingBolts M-14 166 N·m (123 ft. lbs.)
Old Jun 24, 2013 | 09:13 AM
riverjamie's Avatar
riverjamie
Are these the same spec's for 2001 Grand Dodge Caravan? Going to replace my struts today or tomorrow. Also are the cradle and stablilizer bar specs the same?
Thanks
