Identify transmission
Old May 26, 2013 | 09:35 PM
  #21
Fingers154's Avatar
Fingers154
Originally Posted by whyzman
Did you go with the Kevlar or Raybestos clutch material? I have heard that the shifting will be more pronounced, or noticeable, if the Kevlar is used. Apparently, the material is more agressive and the shifting can be "felt." This was from a transmission shop tech I talked with in Colorado. I don't know if that would be the same as the "clunk" you are experiencing?
Did you replace the Torque converter and solenoid pack when you rebuilt?
I have no idea what kind of clutch material it is. I bought the kit mentioned earlier and just installed it. I didn't replace the solenoid pack or the torque converter. I was getting noise in the transfer shaft and it was slipping from second to third so I didn't bother with those.
The clunk is only when shifting into to either forward or reverse from a full stop. It's like the sort of thing you'd expect if your universal joint was shot in a rear wheel drive. Otherwise it shifts very smoothly. It could just be me being hyper-sensitive to everything since it was just rebuilt but it seems odd that it doesn't do it every time.
Old Jul 24, 2024 | 12:49 PM
  #22
Bigcurt's Avatar
Bigcurt
Default Transmission
Originally Posted by master tech
I stand corrected, sorry. It is R0000413AB for the 41TE. Just goes to show i'm not perfect.
How can I find out what transmission I have in my 2008 3.3 liter with flex fuel and it has the transmission dip stick? I got a code po706 range sensor for transmission. Need to know what transmission I have.
