Engine Noise
Old Aug 23, 2012 | 09:47 PM
rPartizan's Avatar
rPartizan
Hi everybody. Have same noise, 3.3l, 2006. I changed belt & pump. Noise still present. ((
Old Aug 24, 2012 | 08:51 AM
b1lk1's Avatar
b1lk1
Originally Posted by grswat
A friend of mine's makes this noise and he told me it was the egr valve. I want so bad to fix it for him but he doesn't care. If you could try unplugging the egr electrical and see if it fixes it.
My van is factory EGR delete and it makes that exact noise.
Old Aug 24, 2012 | 11:05 PM
rPartizan's Avatar
rPartizan
Went today to garage. They said that's belt tensioner. In a few weeks I'll change it. Will see )
Old Aug 25, 2012 | 09:29 AM
grswat's Avatar
grswat
Swing and a miss
Old Aug 25, 2012 | 05:07 PM
highe's Avatar
highe
My 2005 town&country was making the same noise.
changed the idler and the noise is gone.
Ed
Old Aug 26, 2012 | 07:40 AM
grswat's Avatar
grswat
T'is the alternator decoupler pulley
Old Aug 26, 2012 | 10:06 AM
vandad's Avatar
vandad
Thanks everyone for all the input. Was planning to remove s-belt this wkend to isolate noise. However, I don't have the special tensioner release tool and none of my ratchet heads are thin enough to clear the body/frame rail where the tensioner is. Will get back when time allows. Vandad.
Old Aug 26, 2012 | 04:27 PM
Cougar41's Avatar
Cougar41
You can buy the kit which works great or grind down a 15mm socket so you can fit it and a breaker bar in that space.
Old Sep 11, 2012 | 10:04 PM
rPartizan's Avatar
rPartizan
Belt tensioner - changed. Noise still there. ((( Now they say that's alternator bearing. Will try alternator soon.
Old Sep 12, 2012 | 07:34 AM
cappo's Avatar
cappo
my '03 makes the same noise and the dealer diagnosed it as the timing chain. would cost 900.00 to fix. But the service tech told me not to worry about it as they usually last a long time (but the noise is annoying)
