Engine Noise
Old Aug 21, 2012 | 06:21 PM
vandad's Avatar
vandad
Default Engine Noise
My '05 G.C. SXT with 3.8 makes a mild, rhythmic 'whoomping' noise at idle. It has 70k miles, no mil/codes, mpg is 20, no noticeable performance or oil use issues. I noticed someone posted a similar thread (same vehicle and noise description) back in May of 2011 w/ no responses. Since some time has gone by maybe someone else has had similiar issue with resolution?
Old Aug 21, 2012 | 10:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Do you hear this more at start up or after the engine has been running for awhile?
Old Aug 22, 2012 | 02:54 AM
Cougar41's Avatar
Cougar41
Can you post a video so we can hear it? Can you tell what area of the engine it's coming from?
Old Aug 22, 2012 | 08:58 AM
vandad's Avatar
vandad
Thanks for the reply. I had thought the noise was constant, now that I'm focusing on it ..., It wasn't present at initial start-up this morning, air temp. 50 deg. It came on as the engine warmed and became more prominent after it got up to temp. It is only audible at idle, not under load/acceleration and can only be heard from outside the van, behind the wheel with the doors & windows closed all is quiet. The low, rhythmic 'growl' is what I'm curious about.
Old Aug 22, 2012 | 09:14 AM
master tech
I would try to isolate the noise by removing the fan belt. Could be a idler bearing, water pump or alt.
Old Aug 22, 2012 | 09:42 AM
b1lk1's Avatar
b1lk1
Ahhhh, that noise. My van also makes that noise and I have heard a few other Caravans that do it. I'd love to know what other solutions were as I need to find it someday and fix it myself when I have the money to spend. I know in my case, my belt needs replacing so I plan on trying to isolate this when that happens. I also can state that with the A/C on the noise is more pronounced. I'm hoping it is not the compressor bearings since my A/C works well.
I'll post back if I get the chance to isolate this noise in my van.
Old Aug 22, 2012 | 05:02 PM
Cougar41's Avatar
Cougar41
I'm certainly no expert at deciphering noises. Many have complained about the alternator clutch making noises. There's my lackluster 2cs. It sure sounds cyclic and that would lead you to think it's related to something driven by the surp belt as Master T is saying. Thanks for the video. We have a much better idea of what you're dealing with.
Old Aug 22, 2012 | 05:22 PM
vandad's Avatar
vandad
I was presuming it was external. Won't have time to remove serp belt to investigate further for a couple days. Will get back when time allows. Thanks
Old Aug 22, 2012 | 10:07 PM
master tech
Great video, This does help when we can't be there.
Old Aug 23, 2012 | 01:59 PM
grswat's Avatar
grswat
A friend of mine's makes this noise and he told me it was the egr valve. I want so bad to fix it for him but he doesn't care. If you could try unplugging the egr electrical and see if it fixes it.
