96 Caravan 3.3L Wont Stay Running
Old Aug 21, 2012 | 06:40 PM
struculeus's Avatar
struculeus
Default 96 Caravan 3.3L Wont Stay Running
Hello everyone and thank in advance for your help.
1996 Dodge Grand Caravan, 3.3L ~150k miles.
The van belongs to my mother-in-law, who lives about 5 hours away from me. My sister-in-law takes care of her, and does all the driving.
This problem happened earlier this summer. I was there in June and checked the codes - got the P0505 code for the IAC. I replaced it. I guess the code came back within a day or so of me leaving (same P0505).
My sister-in-law was driving the car anyway, and it suddenly died at a stop light. She said it wouldn't stay running for any amount of time, but was able to nurse it home by re-starting it everytime it died, and barely keeping it running (very roughly). It's been sitting ever since, as she's afraid to drive it.
I know how hard it is to diagnose based on someone else's description! But here's what I know -
The IAC is new.
The ECU was replaced last November by reman one. I believe it's still under warranty.
I'm heading over there for the weekend, and would like to fix the van. I'm going to warranty trade the ECU, and hope that fixes it. However, on the chance that doesn't resolve the issue, I was going to (based on my research at this forum):
Check for a short in the wiring under the engine near the cross-member (any helpful clues as to where to look in particular?).
Check the fuel pressure (but I'm not sure why code P0505 would come up if that was the issue).
With a new IAC, what could cause that code to return within 48 hours? Any idea as to what else it could be, or where I should look?
Could this be the Cam Sensor that I've frequently read about?
Again, thanks in advance!
Jared
Old Aug 21, 2012 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Sure it could be a crank or a cam sensor, But it could also be a cracked flex plate too. Once you have the correct code, post it.
Old Aug 22, 2012 | 11:17 AM
struculeus's Avatar
struculeus
Thanks for the response. I'll be over there tomorrow, and will post the codes.
In the meantime, can you explain why a cracked flexplate may cause this kind of performance issue?
Thanks!
Old Aug 22, 2012 | 10:14 PM
master tech
Thats because the flex plate has little window that line up to the crank sensor and breaks the magnetic field. If the windows don't line up at the correct time, the engine start and run badly or has a hard time stay running.
