Lucas Heavy Duty Oil Stabilizer
Old Aug 22, 2012 | 12:26 PM
tattva's Avatar
tattva
Lightbulb Lucas Heavy Duty Oil Stabilizer
hi all,
My virgin post! so there...
What's ur experience been with using "Lucas Heavy Duty Oil Stabilizer" in your Dodge Caravan or Grand Caravan?
Thanks in advance!
tattva
Old Aug 22, 2012 | 10:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
Now you did it, You should have never said this is your first post........... just kidding
The lucas heavy duty oil maybe okay in the early minivans, but the newer van. Because it will cause the check engine light on.
Old Aug 23, 2012 | 09:18 AM
tattva's Avatar
tattva
Default Thanks master tech
however, does it extend the life of the motor oil in between changes?
Old Aug 23, 2012 | 01:55 PM
grswat's Avatar
grswat
I have used the Synthetic Lucas in my vehicles for years on every oil change. In my Dakota the oil pressure improved from a hot idle 20 psi to 25 psi. And in my wife's Infiniti I30 all the upper end engine noise disappeared. I plan on putting it with synthetic oil in my Caravan when I get it running.
Old Aug 23, 2012 | 02:18 PM
Cougar41's Avatar
Cougar41
I haven't used an any kind of additives while maintaining vehicles for nearly 40 years. Never had the need. Never had an engine wear problem. Never had a mileage problem. Maybe I'm blessed.
Old Aug 24, 2012 | 11:10 AM
Darkside 700's Avatar
Darkside 700
If you use a good quality synthetic oil and filter then there should be no need for additives.
