p0406 code for 2006 3.3L grand caravan
Old Aug 24, 2012 | 10:51 PM
randallinmn's Avatar
randallinmn
Default p0406 code for 2006 3.3L grand caravan
what does this code refer to? it's not in my chilton repair manual. I want to fix it myself, is that possible?
Old Aug 24, 2012 | 10:54 PM
steak59's Avatar
steak59
yes, u need a EGR valve.
Old Aug 24, 2012 | 11:07 PM
randallinmn
is that the only possible problem? the scanner also said 'a circuit high'. will replacing the egr valve fix that also?
Old Aug 25, 2012 | 12:24 AM
steak59's Avatar
steak59
Sensor is Inside the EGR valve, they are all molded together as 1 piece. And at this moment, there really isn't any diagnostic u can do, it will be eithe the EGR valve, a bad PCM. or bad wiring(very doubtful).
So, go ahead and pull the trigger on the EGR valve, they go bad A LOT.
Old Aug 25, 2012 | 02:57 AM
Cougar41's Avatar
Cougar41
