limp mode issues
Old Sep 21, 2012 | 03:59 PM
adaml123's Avatar
adaml123
Default limp mode issues
I have a 2001 dodge caravan 3.3liter engine with the 604 transaxle. I don't have any power going to the shift solenoid. I have 12 volts going to the TCM the only power coming out of the TCM is a pink and white wire. Does any body have any suggestions?
Old Sep 21, 2012 | 05:18 PM
Cougar41's Avatar
Cougar41
The solenoid pack gets power from the output contacts of the shutdown relay (EATX relay???). The relay is energized by the TCM. I assume the TCM cuts power to the relay which in-turn cuts power to the solenoid pack when it enters "limp mode", indicating the TCM has detected a fault. Have you checked for codes? The system will generate a P0700 code in the PCM readable by a normal scanner or code reader. That indicates the TCM has stored a code. To read the TCM codes you'll need a specialized scanner.
Need wiring diagrams? Send me a private message with an email address.
