2003 Caravan Fog Light Wiring
Old Oct 1, 2012 | 10:35 AM
caravansxt's Avatar
caravansxt
Default 2003 Caravan Fog Light Wiring
Is there an easy way to tell if my 2003 Caravan has been pre-wired for adding fog lights?
Old Oct 3, 2012 | 12:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Look up inside the front bumper fascia, do you see any connectors that are not plugged into any sensors?
Old Oct 3, 2012 | 05:22 PM
caravansxt's Avatar
caravansxt
Default Fog Light Wiring Search
Thanks for the advice. I believe I did a pretty thorough search and did not find any extra connectors. I even pulled out the headlight assemblies but didn't find anything there either. I didn't take off the skid guard protector but I don't think they are there.
I was hoping the wiring was there so I could just add the light assemblies, the relay and the headlight switch. But I'll probably drop the idea of adding fog lights if I have to add the wiring too.
Old Oct 3, 2012 | 05:31 PM
Cougar41's Avatar
Cougar41
You would need more than that. Unfortunately, once again Chrysler has taken a basic function and turned it into a science project. It uses the BCM/PCI data bus to operate. That said, I don't see why you couldn't rig up a relay, fuse, lights, switch and string some wire. No doubt someone has done it.
Would you like the wiring diagram of the factory install? Send me a private message with an email address.
Old Oct 3, 2012 | 11:17 PM
caravansxt's Avatar
caravansxt
Thanks for the offer but I have the wiring diagram. I may still pick up the fog lights and headlight switch at the auto recyclers and put them on the shelf in case I try to wire them up in the future.
